A Limited Edition of 250 Pieces
Movement is the automatic El Primero caliber 4000SC with 31 jewels, beating at 36,000 bph. The balance bridge is done in shock-absorbing Zenithium. It measures short time intervals to a 10th of a second, has automatic winding in both directions with a central rotor on ball bearings. Full tungsten oscillating weight with guilloche pattern.
The case is brushed stainless steel, measuring 46.5mm. It has screw-in push buttons with specific guilloche pattern. A screw-in crown engraved with the Zenith star, blue-tinted graduated unidirectional rotating bezel and display back. Both crystals are AR-coated sapphire. It is water resistant to 300 meters.
Dial is done in a blue wave guilloce patter with applied Rhodium numerals and white indexes. The strap is blue-tinted vulcanized rubber adorned with wave guilloche in the center.
Here is the Power Reserve version.
Quelle: http://www.timezone.com
