Neues inhouse-Kaliber P3000 - Handaufzug mit 3 Tagen Gangreserve
  • Das Thema hatte ich in einem parallel laufenenden Thread schon angerissen:
    Im Januar 2011 wird auf der SIHH das neue Inhouse-Kaliber P3000 vorgestellt. Es ist das neue Handaufzug-Basiskaliber von Panerai und wird wohl maßgeblich in den Basismodell der "historischen Reihe" eingesetzt. Die neuen Modelle dieser Reihe werden sukzessive die bisherigen Unitas-basierenden Uhren ablösen.
    Hier eine Zeichnungs des neuen Kalibers P3000:
    Offizielle Information zum Werk:
    [align=justify]
    [size=12][b]P.3000[/b][/size]
    [b]Entirely designed, developed and produced in the Officine Panerai Manufacture in Neuchâtel, the hand- wound P.3000 calibre presents the main characteristics of the Panerai movements both in terms of structure and in terms of performance, robustness, accuracy and its long power reserve.[/b]
    The thickness of the calibre P.3000 is 5.3 mm and the diameter is 1612 lignes, a substantial size which traces its origins from that of the movements which were fitted to the historic Panerai models. The calibre is immediately recognisable by its construction, which is similar to that of a three-quarter plate movement: a large bridge, next to another smaller one, covers the majority of the mechanical parts and it is fixed to the bottom plate by a series of screws of substantial thickness, thus forming a particularly rigid structure.
    The movement has 21 jewels and it uses two spring barrels connected in series. Such an arrangement enables long, thin springs to be used, which ensures the delivery of a more even force and also does so over a longer period of time, with a power reserve of 3 days. The balance wheel is unusually large (13.2 mm) and it is the variable inertia type, with four adjusting screws arranged externally round the ring, so that the rate can be regulated without it being necessary to remove the whole assembly. Supported by a bridge with twin supports a fixing much safer and more stable compared to the cantilevered single bridge the balance wheel oscillates at a frequency of 3 Hz, equivalent to 21,600 alternations per hour. It is fitted with an Incabloc® anti-shock device and is free-sprung, so there is no regulating lever.With brush-finished bridges and chamfered angles that is, with the angles smoothed and polished the P.3000 calibre is also fitted with the device for the rapid adjustment of the time: a star wheel with 12 points and a small spring clutch enable the hour hand to be moved one hour at a time, without interfering with the movement of the minute hand or the operation of the watch.
    FunctionsHours, minutes, small seconds
    Technical specificationsHand-woundPower reserve 3 days160 components21 jewels1612 lignes in diameter5.3 mm thickTwo spring barrelsFrequency of oscillation 3 HzIncabloc® anti-shock device
    This new movement will be fitted in watches whose price will range from €5,000 to €7,000 and over the years additional complications will be added.
    The company is committed to producing all its movements in house at some time in the future but for the next few years will continue to produce watches with outsourced movements.
    The movement is already in production & watches fitted with it will be available immediately after their launch in January 2011 at the SIHH in Geneva.[/align]
  • This new movement will be fitted in watches whose price will range from €5,000 to €7,000 and over the years additional complications will be added.
    :eek:
  • :bash: ...wer alles liest ist klar im Vorteil...
    Das ist aber schon heftig, wenn man die heutigen Einstiegspreise damit vergleicht... Wird dann immer schwerer "Nachwuchskunden" zu kriegen.
  • Das mit dem Basispreis ist ja keine Überraschung ... Rolex fäng mittlerweile auch bei rund 5K an ... Das ist das neue untere Limit. Und die Uhren werden sich trotzdem verkaufen.
    Bin mal auf das Kaliber im Alltag gespannt - die Entwicklungszeit war doch wieder recht kurz. Mal sehen, wie "fertig" das Werk ist.
  • Der Weg zur Manufaktur und unabhängig von ETA kann ich nur beglückwünschen. :gut:
    Trotzdem schade, dass die nicht die Frequenz auf 28.800 A/h gesetzt haben. Ist doch heutzutage Stand der Dinge.
    Klaus
  • Ich sehe es auch so. Panerai hat in der Vergangenheit (damit meine ich die im letzten Jahrtausend) eigentlich nicht durch uhrmacherische Kunst bestochen, sondern durch wundervolle Uhren mit zugekauften Werken. Von mir aus kann das bei den historischen Pams auch so bleiben, zumal das Unitas ein absolut robustes und einfach zu wartendes Werk ist - mit der Veredlung durch Panerai ist es ausserdem für meine Bedürfnisse exklusiv genug.
  • Sehe ich auch so...das Unitas passt zum Charakter dieser Uhren und ist in Bezug auf die Pre-V Lumis auch historisch korrekt.
    Die Preisentwicklung finde ich erschreckend, so wird aus einer simplen Uhr immer mehr ein elitäres Spielzeug.
  • Hhmmm,
    Auf den ersten Blick erkennt man ja das 'Baukasten' Prinzip der neuen OP 'inhouse' Werke.
    Optisch jetzt nicht unbedingt ein Leckerbissen. Das kleinere P999 ist dann doch etwas schmucker unter dem Glasboden an zu schauen .
    Der Preissprung bei den Modellen ist dann schon eine ganz andere Liga. Ich bin gespannt wie das der Kunde aufnimmt.
    Ich erinnere mich an eine Aktion bei IWC bei denen (nach dem die Uhren auf dem Markt waren) nach dem Kauf 15% 'nachkalkuliert' wurde und es gab das Geld beim Händler zurück. ;)
    Sorry aber 5000-7000 € für ne Stahl Pannie mit diesem Werk kommt glaube ich nicht so an :bash:
  • Endlich gibt es jetzt so ein Handaufzugswerk bei Panerai, der Schritt war nur konsequent, nachdem die historischen Modelle alle nach einem verlangen und ein umgebautes Valjoux 7750 doch eher eine Notlösung ist.
    Lg
    Eine Handaufzug Kaliber gab es schon letztes Jahr (P9999) ;)
    und ein 'umgebautes Valjoux 7750' ist und bleibt (auch ohne Chrono) ein Automatikwerk ;)
